compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Sat Jul 31, 2010 9:15 pm
How did you check everything else? Did you pull the cas and spin it? Do you have injector pulse? ( injectors ticking) does your ecu bulb light up when you turn the key on? You need to specify what tests you have done and have eliminated for possibilities, otherwise that's like calling someone and asking them what's wrong with your car while sticking your phone in the engine bay...just doesn't work. No spark could be a number of things, eccs relay, no power to ecu, bad grounds, bad ignitor ( must be real savy with a dvom to bench test properly) bad cas. Let us know what you have done and we will go from there. If you are unsure about something ask. ..I take it this is your first sr?
