Blackmobile »
https://forums.nicoclub.com/blackmobile-u106210.html
Tue Apr 06, 2010 7:13 am
you've got the same issue as everyone who has an issue with ddm kits, they reversed the wires. you can see it in your 2nd pic, the black wires should line up, but it shows that your red goes to black and your blue goes to black so they reversed the wiring. like people said, try to flip the plug over and jam it in, if it doesn't go in then trim off the little nub that blocks the plug from going in the wrong way.
your windows won't go up cause it's a function that is disabled when you unhook your battery, just do the auto window roll up procedure. roll the window down, then roll it up and hold the button for another 5 seconds after it's rolled up, it should reactivate. and to get rid of the check engine light, just disconnect your battery again for a minute and it'll go awyay.
