help please
red93_240
Car: 93 nissan 240sx
i was just wondering if anyone could helpme figure out the problem with my car.
i just rebuilt my engine and everything was going fine.but now that there are about 2000 miles on the motor my carmisses from about 2k -4.5k rpms.
sometimes it is really bad when im at 1/2 throttle the car stalls so bad that it will not go anywhere and will loosespeed untill i push the pedal to the floor.
a couple of weeks ago the car overheated because my water pump was leaking but i put another on it.
but now my temp gauge fluctuates.any help would be much appreciated.
[s3]
Run ECU diags and check for codes.
red93_240
well what codes should i be looking for.shouldnt my check engine light be on?
[s3]
Some codes do not pop engine lights
MAF sensorTPS sensorTEMP sensorO2 sensor
etc
red93_240
ok i see what ur saying now.a quick quesiton.could the cts cause the car to act this way?the reason im asking is that is what im thinking it is
[s3]
It might, code 13 is what your looking for
If your cts is missing/dead, your car should automatically turn on all the fans and your idle raised.
Check ECU, best bet.
