Help Please!!
VirginiaPS13
Car: 89 S13 Coupe
2005 Acura TL
May it will get more trafic here, I really need some help, im not finding anything when i search.zerothread?id=435587
Vegascorbin
Car: 1990 240sx dirt track race car
Install the Head per the FSM. Before installing the Timing Chain set the Cam etc at #1 TDC. The following Tech Article covers the Timing chain on the KA24E motor pretty well.
Use care when installing the oil pump (you are useing a new one right?) It is very easy to have it off by a tooth. Not the end of the world but a PIA to re-do to get it right.
http://www.nicoclub.com/articles.php?id=168602
That should hep get you on the right track.
VirginiaPS13
Car: 89 S13 Coupe
2005 Acura TL
thank you.
