HELP PLEASE!!!
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
180sx2fast4u
Car: 1991 240sx
Ok heres my problem. I drove my car home it was fine, woke up started it and could instantly tell there was a problem. The car was smoking and had strong gas smell ,horrible idle at first, once i gave it gas it jumped up in rpms and then the idle was fine. The issue then was it was in safe mode and wouldnt rev above 2500. I turned the car off and turned it right back on and it started fine. Waited 5 minutes, started and the same problem. Anyone had this same problem?? Need my car back
180sx2fast4u
Car: 1991 240sx
want to add, there is no check engine light
Evilvdub
Car: a couple
Sounds like it's loading up on cold start. I've seen cars over 60k have some issues usually a plug change and an injector cleaner works
Return to “3rd Generation Altima Sedan (2002-2006)”
