Kustom Kreations »
https://forums.nicoclub.com/kustom-kreations-u102284.html
Sun Dec 14, 2008 4:48 pm
I have a 91 240sx with the stock Ka, I had a cooling problem, and I noticed it was the hose that goes from the water pump into the intake manifold, after I changed it, I noticed that after the car heats up, all the pressure is scaping from the reservior tank, the coolant in there is bubbleling and you see the steam leaving the tank, I also see some steam coming from the rad cap, My question is what is causing the pressure to scape to the reservior tank, and how could I fix it?
thanks in advancedAl
