telcoman wrote:
Sounds like a bad switch contact in the rear position?Is there a plug anywhere near the switch that could be loose?
You could take it to the dealer for a quote or sell it to a midget ?
Telcoman
thanks guys for the replies..i checked the plugs leading to the switches and everything looks fine. I unplugged 3 different switches but wasn't quite sure what did what but did this in hope of resseting something, no luck. however i did do the whole unplugging thing while i had the battery disconnected. in case you ask why i had the battery disconnected, well i read somewhere here that unplugging certain cables from the drivers seat may deploy the airbag yall know if this is true?
G_whizz- see thats what has me real confused, i dont think is a problem with the motor also cuse other wise all other directions wouldn't function, well at least both the back and forth.
Rn79870- not quite sure how to do this, but guess what i'm gon be doing this weekend? yea ima take this sucka apart! i'm not going down without putting up a fight...i dont know but right now telcoman's idea of selling it to a midget does sound like a great one.
