HELP please
nraf
Car: Car audio/video
Ok my 240SX just had a little mishap the front breaks are gone on me completly now. I want to switch to the 300ZX breaks
Can any one help me out and let me know where i can get info on what to do?
Please dont tell me to hit the search button I did and didnt find anything that really helped me so please
help me out i dont have front breaks waht do i need to get to do the converstion
and how do it do it please let me know
thank you
240marcuSX
Car: E34 525i
E46 M3
i think pdm sells a kit with everything you need for a front 300zx brake conversion, its like a grand though, also youll have to get 5 lug wheels, thats about all i know, but no one else was even giving you a clue.
240marcuSX
Car: E34 525i
E46 M3
Here and i dont think the brakes will fit behind any wheel smaller than a 17, or is it 16, im not sure.
BadMojo
Car: 2007 Mazdaspeed 3
You can get some remanufactured calipers from a place like Autozone . They'll be affordable and perfectly fine to use. Rumor has it that they'll refund your core charge if you give them your old 240SX calipers, but this would be errr... unethical. You'll have to decide if you want to get the 26mm or 30mm calipers.
There's lots of good info here...
You can get fresh rotors and pads from Tire Rack.
You'll also need some new brake lines. Do *not* use your rubber 240SX lines with your new calipers. You need some custom lines that will properly fit your shiny new (remanufactured) calipers. Try PDM Racing or [URL=http:// Project Silvia for those.
The Importnut site linked above should list the tools you need and any other minor OE parts you'll need. Don't forget to get some good brake fluid.
You may also want to read a bit about the Master Cylinder swap. Not required, but those who've done seem pleased with the results.
