Import_Ant »
https://forums.nicoclub.com/import-ant-u16968.html
Tue Oct 09, 2007 4:09 am
I'll take some pics of mine this weekend while I am out @ the garage but if I recall correctly, there are at least 5 nuts and bolts holding the intake manifold directly to the head.
There may be 2 long bolts you forgot, they're a PAIN IN THE *** to get to, they are in the middle of the manifold, underneath all of the vacuum lines.
Did you pull 2 long bolts out, approx 8" in length? if not those are the ones you're missing.
as far as manifolds go are you asking about an intake or exhaust manifold? I got my SOHC turbo kit from IAP. JGS Tools makes a SOHC turbo kit as well and there are some other generic manufacturers whos names escape me at the moment. I used my stock intake manifold and it worked just fine. If your goals are at or below 450hp or so I would not reccomend spending the money to upgrade the intake manifold.
If you want to throw around money and feel you must have one, Xcessive manufacturing makes one. ->Link
but that $300 will net you alot more performance elsewhere (namely in a lightened flywheel or upgraded cam.)
