Help Please
turk182
Car: 94 Infiniti Q45
Could somebody please tell me the easiest way to remove the alt. from my infiniti Q45. i'm havin a biotch of a time
qsiguy
Car: 1994 Infiniti Q45 Turbo
Easiest way is to take it to your Infiniti Dealer or trusted mechanic. That's what I did last time. If you are going to do it yourself it requires quite a bit of work. The a/c compressor has to be unbolted and moved to get to the alternator. In case you didn't already know you have to get to the alternator and a/c compressor from under the car.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Hey turk, welcome to NICO.
Do a search in Infiniti Online Mechanic Forum fo rseveral helpful posts.
Do use an OEM rebuilt alternator so you don't have to repeat the labor in a year or two.
http://www.infinitipartsusa.com
turk182
after you get the compressor unbolted ! where are you suppose to move it too. cuz i still can't get to the back of the alternator.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Read the posts in IOM.
superuber
turk182 wrote:after you get the compressor unbolted ! where are you suppose to move it too. cuz i still can't get to the back of the alternator.
Just push it aside. It should move enough. I have done mine twice.I've got it down to a science! I assume you are under the car? No lift=No fun!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
When I did it I didnt remove the AC compressor or anything, and I did it primarily from the top. It really wedges itself in there and once you free up the front and back it comes right out.
