Help please
slowasss13
Car: s13 sr20det tomai o2 housing blits down pipe hks pro power exhust greddy v spec inercooler 6 puck s
I recently bought a 1990 300zx and i found out one of the spark plug wires hasnt been connected and its been runin on 5 cylinders. I changed the plugs and connected the last plug wire. Now the car wont idle right. Either the car idles at like 300rpm and then stalls or its up at like 4000 and jumps around. I don know what the problem is. Please help. Someone told me i was the idle air control but i dont know what that is.
slowasss13
BUMP
DustinZ
Car: 1990 Z32, rb25 s13, 1980 S130 10th anniversary, 1978 5speed fact ac s30, s2 rb26 on deck!
The car has no plug wires just coil on plug. You might have a vacuum leak on the balance tube or a vacuum line loose.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I assume when you say plug wires you are referring to the wires attaching to the individual coil on plug coil packs? in which case are you sure that that coil pack is good? how about the ptu?
300scotties
i'm gonna go with the PTU also.
had a simliar problem onm y 93. replaced my ptu and it's been smooooooooth ridin.
slowasss13
Hey thanks for the info. Where exactly is the ptu and what exactly is it. Could it also be the IAC?
300scotties
slowasss13 wrote:Hey thanks for the info. Where exactly is the ptu and what exactly is it. Could it also be the IAC?
PTU- Power Transistor Unit
Located on most Z's on the front left side.
