Help! Please!
LAWLESS240
I HAVE A PROBLEM WITH MY 90 240SX. WHEN I TRY TO START IT, IT ONLY STARTS SOMETIMES.WHEN IT DOES START IT IDLES VERY SMOOTH FOR ABOUT 5-10 SECS. THEN IT DIES. IF YOU GIVE IT ANY THROTTLE IT DIES. I HAVE REPLACED MY COIL, FUEL FILTER, AND SPARK PLUGS. I TOOK A READING ON MY TPS IT VARYS FROM ABOUT 830 OHMS TO ABOUT 1.3K OHMS. IS THIS THE PROPER RESISTANCE OR IS MY TPS BAD?? ANY HELP WOULD BE GREATLY APPRECIATED.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Fuel mitxure too lean during cold start.Restrictions in the air intake.Ignition system problems.
Can you do a voltage test on the TPS while the car is running at various rpm's?
LAWLESS240
I CAN'T MAKE THE CAR RUN LONG ENOUGH TO DO A VOLTAGE CHECK AND IF YOU GIVE IT ANY THROTTLE IT DIES. :mad:
