Cgeigert »
https://forums.nicoclub.com/cgeigert-u48530.html
Sun Aug 14, 2011 3:48 pm
So I've had this one for over 6 months, I didn't do the swap. Car has: Greddy FMIC, Walbro, S15 T28, otherwise engine, ECU and fuel system is stock. Could use a CAS adjustment but otherwise has been running fine until recently with only a random misfire at idle. The only thing I changed recently was I added a TurboXS manual boost controller. So now when I drive when the engine is cold it idles, runs and boosts fine. After a few minutes once it gets to operating temp it starts to misfire at idle and won't hit boost, just stumbles if I try to WOT. The only other thing I've noticed is I smell unburnt gas more. This is what I've done so far...
-Bypassed MBC, no change
-Checked all connections and clamps, replaced a few vacuum hoses. All looked tight and felt tight
-Swapped MAF with my other SR, no change. I redid MAF harness wire and soldered and heat shrunk it.
-Checked injectors and coils, replaced plugs gapped at around .32
Problem is totally unchanged, nothing that I have done has affected the way the car runs. What should I do next?
