Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue Feb 01, 2005 9:10 am
check for boost leaks. many times you feel a loss of power like that, it's air escaping from the intercooler plumbing because a couple clamps aren't on tight enough.
There are two other causes of this. Clutch slippage, which you would feel as a shudder in the clutch pedal, or bad turbo. Bad turbo would leave oil in the IC piping, and the compressor wheel and turbine wheel will have a lot of play in them if that's the case.
EDIT: S13Guy, if you can't contribute anything useful to the thread, please don't post.
I also cleaned the thread up so it gets to the point faster.
