yodawill2000 »
https://forums.nicoclub.com/yodawill2000-u27169.html
Fri Dec 14, 2007 7:27 am
the atf filter is pretty easy if you can get the J on Jackstands.Drain the fluid by taking out the drain plug.About 3 1/2 to 4 quarts will come out. The rest stays in the transmission.then take off the pan bolts and drop the pan.The filter will be right there.I suggest you get the filter, gasket and a new crush ring for Joe at everythinginfiniti.com before you start , and obviously enough transmission fluid to top it back off when done.Be sure and get all the old clutch material out of the pan and clean it up good before putting it back on.
