Help please! Rounded fan clutch nut
brickbox
Car: 2011 Nissan Pathfinder 4x4
2011 R51. What a PITA.
Apparently the PO has tried to replace the fan clutch but was unsuccessful.
All 4 nuts were ON TIGHT! I had to use a breaker bar and rapidly move it to break the nuts. Otherwise I was spinning the pulley trying to remove the stupid nuts. Got the 3 visible ones off and voila the last one is rounded. I can get a 12 point on there but it slips as soon as I put any force into it!!!
How do I remove the last rounded nut? :wtf2:
Mike W.
Car: 2003 Infiniti QX4 with a drinking problem. Gone but not forgotten
2002 BMW 525it
2002 BMW 530i/ manual trans
The dark side, 2008 4Runner.. We'll see.
First step is easy if you're using a 12 point socket or wrench, use a 6 point. While 6 point sockets aren't quite as convenient as 12s, they'll get a lot more stuff off.
If that doesn't work I'd go for a vice grips.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
brickbox
Thanks! I have that exact set and tried getting it in there. The space is too narrow. So after 2 hours of liberal soaking and hammering with a decent amount of force the nut spun finally. What a POS. The PB Blaster was steaming as I hammered it with the corrosion breaking loose.
New problem though - I was an idiot and forgot to put cardboard on the radiator. The old clutch was seized to its shaft and I had to yank it off. And this happened
Looks ok to me to still use the radiator with the pins a little bent. What do you guys think?
brickbox
Apparently lost my time window to edit...
I got new flange nuts on there from Home Depot. And they are on there as tight as I can get them by hand. How tight do they need to go on?
To go any tighter I would need advise on how to lock the pulley in place...
Mike W.
2002 BMW 525it
I'd go with standard torque specs, here's a list, http://www.dansmc.com/torque_chart.htm/ I can't tell from the pic if it's 6 or 8MM. The way to tighten (or loosen) on something like that is to use one wrench on one of the nuts, locked against the hub, then turn the one you're trying to tighten or loosen while it's held in place. I just did this on my Grandsons Toyota a couple of weeks ago, same design. It's not the smoothest operation, but it works.
The radiator is probably ok, the fins are no worry at all, that middle tube is the one thing I can see that might be a problem, but I think you'll be ok. Just keep an eye on it when it gets hot and under pressure.
CJstem00
Car: 2008 Pathfinder SE 4wd
Ugh- I'm doing that job today.
brickbox
Thanks Mike!
I’m doing the spark plugs change too. Once that is done, I’ll get everything together and do the cooling system bleed. My plan is to put the radiator cap which is non vented on there and leave the cap off on the reservoir tank?
brickbox
CJstem00 wrote:
Sat Oct 03, 2020 8:45 am
Good luck - hopefully you were able to get the little nuts off without buggering it up.
CJstem00
So, in and out in 90 minutes. Old one was new. Not my issue! Replaced anyway, and moved on. Did the throttle body reset thing, BOOM! Idle normal, no fan rush on start and idle. Still have a O2 sensor to take care of this week. I'll write a post when I'm done, hopefully sooner than later.
