Help Please!! P320 Code?
jarred15801
Car: 1997 Infiniti Q45
I changed my sparkplugs and since then my car runs terrible, it sputters and sounds like nearly stalling at stoplights. Sometimes it seems fine and sometimes its terrible. I believe the code my mechanic told me was a P320 code but i cant find that in the manual. Help please...I know the last two digits were deffinetly 20, and it most likely relates to the sparkplugs or ignition system becasue it started right after i changed the plugs.
Modified by jarred15801 at 12:17 PM 8/22/2008
96Qowner
Car: 1996 Q45
Maybe P1320?
P1320 Ignition Signal, Primary
http://www.infinitihelp.com/Ow...1.htm
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Sounds like another coil problem.......
jarred15801
yeah i checked again and your right it was 1320. This means it could be any of the coils or plugs then correct?
wouldn't it most likely be one of the plugs since it ran perfectly fine before i changed them and now it runs terrible? or is it possible a coil got messed up just from plling them out?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
It could well be the plugs if you didn't use the OEM recommended NGK.
In any case, it should also have stored a cylinder misfire code.
bullittandy
[QUOTE=jarred15801]or is it possible a coil got messed up just from plling them out?[/QUOTE]
I think this what happened.
Q45tech
Exactly!
Owner or technican abuse from overly agressive removal of coil and coil to plug extension.
Based on some life studies published by Delco and others it appears that the recent coils might be considered one time use. Or at least a high probablity of some failing just after plugs are changed.
Coils, plugs, injectors, cats, belts, idler pullies: just wear and tear items that should be budgeted for to maintain as new.
jimbyjimb
Car: 1992 Infiniti Q45
I've never heard of cats failing. Being murdered, yes, but failing? It's not that I don't believe as much as I am curious.
Q45tech
Buy a few shops and see for yourself how the quality has declined since the 1990's. Especially after 2001. Not just Nissan but every manufacturer in an attempt to keep selling pices down vs REAL inflation.They all last thru 80-100k but seem to fail faster soon after but I am use to no cat failures in 90-93 even with 400k.
jarred15801
could it be becasue i used the NGK Iridiums instead of the patinums?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Definitely the wrong plug.
RTFSM!
jarred15801
I know the manual said platinums but some people on here said they used the iridiums and had good results so i figured id give it a try. But then again some people said there car did not run right so im gonna pull them and take them back today. thanks for the help
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The OEM specified plugs work so well there is no need to experiment.
Never a problem on the VH series.
