help......please, over heating problem....very frustrating
StonedRhyder
Car: 91 240sx ka24de
okay, i put this here in hopes people will look at my post in the Nissan Online Mechanic under, "car still overheating after new radiator.....!help!"
would like to take my car to the wisconsin dells auto show friday..... so anything and everything said could help out at this point.... thanks
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Coolant age and PH?
OEM new or after market radiator?
Water pump age?
Is the coolant and overflow tank full?
TroubleBound
Car: 1992 240SX Hatch
Thermostats go out too and they're cheap, did you try that?
Razi
Car: Moo
KA's are a pain to bleed air from.
Have you bled your coolant on an incline?
flohtingPoint
Car: 2004 Z16 Corvette Z06
Head gasket perhaps?
StonedRhyder
well ask i type the water pump is out, waitting for it to dry off b 4 i put the new one in. i replaced the thermo, temp sensor, fan relay, plan on flushing it and bleeding it on wheel ramps after the water pump. when i bleed it should there be any air bubbles coming out of the 10mm bolt bleeder? like ZERO? ph will be set up for a bit on the cool side since i live in wisconsin. the rad was just an oem - cant get the one i want yet till i get the turbo. no oil in the rad fluid and no rad fluid in the oil,nor is there any white smoke. yes the tank and rad are full of fluid......will post after i put in the new water pump and bleed it on an incline. Thanks for the ideas!!!!!!!
StonedRhyder
WOW to add to the frustration, i went and opened the new water pump box (45min drive to auto zone) and they gave the the wrong one!!!!!!!!!!!! now i have to wait until 2marrow after work to pick the part up. god dam that makes me so mad, how hard is it to check numbers and make sure they arnt off! will post after i put it in..... about 6-7pm 2marrow
TroubleBound
Damn man that really blows they gave you the wrong one. Hope it ends up fixing it.
Also i dont know what you mean about the bleeder bolt or whatever when i replaced my thermo/water pump i just left the radiator cap off and waited for the bubbles, squeezing the hoses and parking on an incline. Took like 15 mins before it stopped bubbling. Stopped overheating though.
Dattebayo
Stop making threads in Gen chat about tech stuff. :slap:
s0m3th1ngAZ
Car: 96' Miata
2014 Focus ST
Dattebayo wrote:Stop making threads in Gen chat about tech stuff. :slap:
Why not? Not like anything useful gets posted here.
StonedRhyder
just put in the new water pump, and......................fack!!!!! still over heating!!!!!!!! i also ran and got a new cap with out any luck. im about to go and take it to a shop and get it up the... god dam man, i did notice that when it overheated and i pulled over to look at the eletric and it wasnt going. i replaced the relay for it also, and that dam temp sensor. i didnt see any air bubbles coming up. i did have the car jacked up, and didnt see any air bubbles. will try again 2marrowd to bleed it. when i took the rad cap off there was sucktion to it...... isnt there going to be pressure instead of sucktion? no leaks, ph is good and ive tried eveything ive read and was told to do. thanks for the help... when you take your rad cap off, how big is the flow? I see a very very slow flow, and it isnt constant. It will push and then stop, push and then stop. not really swooshing in thered. Belts are tight, well i have about 1/4in play in it, belts arnt sqeeking. im just lost.... dam car needs to take a sidways slide off a cliff!
Dattebayo
Because tech threads don't belong here. THAT'S WHY. :poke:
