davidfromdallas »
https://forums.nicoclub.com/davidfromdallas-u107413.html
Sun Jul 27, 2014 2:40 pm
First post here, but have consumed much great information including topics on other smoking M35s. Any and all replies and help would be greatly appreciated.
The car info:
-- 2006 M35 Sport, 112,000 miles
-- Mobile 1 5w-30, changed every 5K - 8K as suggested by Blackstone Labs who does my oil analysis at every oil change
-- Latest oil analysis shows no indication of engine wear (metals, etc.) in the oil, in fact no abnormalities at all when compared to prior samples
-- Spark Plugs changed at 108,000
-- Air filter changed at 108,000
-- At spark plug change noticed a small amount of oil leaking into the spark plug tube on the #6 (I think) cylinder (driver's side closest to the firewall) - this is (I think) the valve cover leak I have read about here.
My symptoms:
(1) Oil consumption is up;
-- previous to 90K miles I would change every 5K-8K miles) and not have to add a drop of oil
-- Now I am adding 1/2 qt. every 1,000 miles or so; this seemed to start happening quite suddenly (everything fine on one oil change; next oil change - wow, not much oil there).
(2) Gas mileage is down
-- was WAY down until spark plug change
-- seems to have improved - now at 18.1 for mostly city and 18.5 for city/hwy combined; this is about 1 mpg less than the normal average for the car
(3) Now the problem
-- when cruising at 70 mph on the highway, then putting my foot in it to accelerate the car tends to blow a lot of blue smoke under full throttle - enough that it is embarrassing and looks like a mosquito-fogger. This is a 70 to 85-90 acceleration run.
-- When accelerating from a stoplight at full throttle to about 50 mph there is no smoke even though I rev to redline
-- When running steady throttle or light acceleration there is no smoke
-- There is no smoke at startup
So the question is "where should I start the investigation"? From the posts on this forum it seems like there are some possible culprits:
-- Valve cover leak; but wouldn't that cause smoke all the time not just on highway full-throttle runs?
-- PCV valve - clean / replace
-- Rings - do a compression test; but wouldn't it smoke all the time if this was the problem?
-- Some other dreaded disease I haven't seen or thought of yet...
Like I said - any help would be greatly appreciated...
DJ
