Gino »
https://forums.nicoclub.com/gino-u21116.html
Fri Dec 29, 2006 2:13 pm
if the bolt on the handle is tight, then you need to adjust the e-brake at the hub rear hub. Our brakes have a drum inside for the ebrake. You need to take your rear wheels off, there is a little dust cover pop that off. Use a flathead screw driver and theres a little knob in the hole. You have to turn the knob until it tightens (i *believe u have to spin it in a upward motion). Once its tight, turn the knob back about 5 or 6 knotches. (make sure the ebrake is down. If the bolt was tight on it, i like to loosen it up a little bit so theres room for more adjustment in the future with the bolt, instead of having to take the rims off again). before you put the rim back on, with the ebrake down make sure there is no resistence. If there is, maybe go back a few more knotches. Check the ebrake itself, i usually like mine to go up atmost 45degrees. goodluck.
