centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Fri May 23, 2008 12:45 pm
I can't drive at night! For two days now! I don't know what to do. The issue is that my headlights (low beams) will not turn on. First I check fuses to find I have one for each side and they're both fine. Then I checked the relay which looks fine in and out and even tried a new relay from the parts store but that didn't work. Turns out, the relay may only come into play when the high beams are on from what I can tell. So I pulled a bulb, not suspecting it, and it is fine. My other lights work great. Corner lights and all with first click work. Turn signals work when car is on. All stay on with second click and still work but no low beams are added. Turn signals still work in second click and high beams can be turned on and off so they're fine. There's no warning lights on the dash board and the high beam indicator works properly. I've searched and found none of the same situation. There's one guy who said slapping his hood affected on side and I'm curious about this because I always have to slam the hood to get the latch to close. I've been posting, but in all the wrong places I guess so maybe this spot will get some actuall advice. So, please, what should I do! I really need the low beams, obviously. Thanks in advance.
