HELP PLEASE! Just bought '07 G35 sedan
NOLAgirl
Car: 2007 Infiniti G35 Sedan
Hey guys!
I just bought an '07 G35 Sedan and I am having a bit of trouble with incoming phone calls when my phone is paired with the vehicle. The problem I am having is my phone not ringing when an incoming call is coming through. I have an iphone 4s. The number comes up on the screen in the dash, but not ringing sound...even after I have selected a ring tone.
Any suggestions? :gotme
Thanks yall!
:wavey:
telcoman
NOLAgirl
Welcome to NICO
Have you checked the volume control on the vehicle audio system
If that doesn't clear the problem try un pairing and re pairing your phone
If that doesn't work borrow a friends phone, pair it to your vehicle and try that
Good luck
Telcoman
audtatious
Hmmm....My iphone 4s works fine with my '08. I have not paired it yet with my '07 but the systems are the same and I would expect the same results. I'll check it tomorrow.
With Nav there is a phone setting for "Use Vehicle Ringtone", see if that is on or off and try the opposite setting. But, I assume you have the base/Premium system since you mentioned "Select Ring Tone". My '08 coupe is base w/Premium and it works fine. The '07 is Nav so it would be different than yours anyway.
nickethomas
Did you ever find out an answer to your question...please post what you discovered.
Thanks.
