HELP PLEASE!!!! - how do u install an amp in a nissan versa
Post all your Nissan electronics, car audio and stereo questions here!
13bluvo
Car: Nissan 180sx
I have to install an amp and a sub into a nissan versa, can anyone show me how to.like where is the hole to run power supply cable from the amplifier to the 12volt battery. im just stuck on the power to amp situation
PoorManQ45
There is usually a gromet where the hood release cable runs through the firewall. You can use a coat hanger to push through it and then pull your power wire.
Clipsed
Car: 07 ALL BLACK Nissan C11ST, 01 Mustang GT Vert, and 94 Suzuki Sidekick JX 4x4.
Go to the Versa Forums, and look at my fog light how to, you can see how I ran the wire from the engine bay to the cabin, I used the same method for both the amp power wire and the power wire for the fogs.
