Help please guys
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
LOL there is no such thing a swap-wiring.com. Dispute that for sure. In the meantime, source a new harness. Sucks but what else can you do? :gotme
Omni
lol i am
but how do i dispute something when in his add he says no returns??...also a friend of mine if letting me try his harness..so let see what happens..he felt sry for me cause he seen that i was really depressed hahaha
Darius
It doesn't matter what his "no return" poilcy is. He misrepresented what he sold to you and that is fraudulent. Offer to send the harness back in exchange for a refund. If he doesn't go for it, take it up with paypal and file a dispute. They will usually come through.
Omni
ok will do..and uhm i think my cas is bad so i plug my friends harness up and seems good so far...engine cranks over and nothing so so i think its my timing is off...so i take out the cas set the timing back to TDC and a though came to mind i should spin the cas to hear is my injectors click and i get nothing..absolutely nothing...but when i plug the cas plug..the fuel pump goes off and i hear a click at the end...but when spinning the cas by hand manually no injectors clicking..could it be the wheels thats messed up and if there a replacement i cant get instead of buying a whole new cas??
Omni
can injectors hit a flat spot guys??
Darius
What do you mean by a flat spot? Yes if they max out, otherwise no.
Omni
i meant like if they havent been used in a while and just been sitting there but i guess like u said they would have to be maxed out and mine are nowhere close to that hahah
