HELP PLEASE!! ELECTRICAL!
antvill240
Car: 89 240sx s13
I have headlights,breaklight,and interior lights...no dash lighs or running lights...when i change the fuse,turn the lights on, blows right away!. its an 89 s13
ashoe
Car: 1996 nissan 240sx se, 2006 subaru wrx
Well if you blow the fuse right away then you almost certainly have a short somewhere. The hard part is finding it. My method is to look for damage to wires as well as test with a multi meter. Its a tedious, time consuming, and annoying process... Have fun!
Vegascorbin
Car: 1990 240sx dirt track race car
Like ashoe said, it is a time consuming process.
Few things that may help narrow down the problem area:Did this sudenly start or has it allways been this way?Did you change anything recently no matter how small or seemingly unconnected. If so undo the change and re-test.Look over the wire harness very closely as this type of problem many times can be found by locating a pinched or cut wire someplace.
Take your time and follow the wiring diagrams in your FSM.
JAAS
Car: 93' S13
A FSM can really help you here..
Lookup the fuse that it's blowing and that should narrow down which wires to test..
