Help Please, carbouretor rebuild gone bad
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
eviedechant
Car: 1980 nissan 720 pickup
I thought i would surpirse my husband and put the rebuild kit in the carbouretor... how hard could it be right?? Now I have wires that I have no idea where they go one is coming from the soleniod and the other from the automatic choke
PEZi
hey... i'm not currently home to pull up my manual, but unless someone else gets to it before i do i'll try and look up the diagram when i get back
eviedechant
Thank you so much !He found out last night what I did and was tickled but not happy that I couldn't put it back together
PEZi
so i'm not really coming up with anything here.... i know on the newer models there is a harness for these to go into... but not sure about the '80 model
you should be fine running the electric choke heater wire to the battery... but i'm not sure on the one to the solenoid... you could try running that to the battery as well but i'm not sure how it would work out
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Run both wires to the positive side of the coil.
Return to “Datsun 720”
