loystock »
https://forums.nicoclub.com/loystock-u10145.html
Wed Dec 01, 2010 8:01 pm
A faulty (shorted IACV can also 'kill' your ECM (driver/power transistor inside controller). Pull it out, check resistance of stepper motor coils 20-30 ohms (pins 2-1, 2-3, 5-4, 5-6). If Ok, clean the IACV and re-install. procedure is in the 'sticky' in this forum. You may have to use a new gasket. Also take note that there are other sensors that could IACV to be erratic
