!!!!Help Please!!!! 240sx gauge problems
Bigrolla
my speedo changes when the key is on and engine is not running and is of sometimes or most the time when it is running, sometimes hitting dash fixes and ideas what my promblem is?Fuel gauge isnt work, I bought this car with a sohc to dohc swap i believe this is a dohc cluster
240Knightrider
Check for loose wires around the cluster. Take the whole dash out and inspect the wires.
Bigrolla
also gauge doesnt always go back to 0 and fuel gauge acts like its off
Bigrolla
any other comments?
240Knightrider
I would still guess you have a loose wire somewhere, or check your relays. You might have a relay going bad.
Bigrolla
also i noticed the leds on left side dont work like check engine light and all, i checked cluster couldnt find a short or anything in the wiring
240Knightrider
I think maybe it is a relay, try to find someone to run a diagonostic check on it. Your relay might do that, I could me wrong. Go to autozone I heard they werent too expensive for a diagonostic check.
Bigrolla
maybe this will explain some, this car is a 240sx with sohc to dohc swap, i remeber reading to just replace the tach in the sohc cluster with dohc tach, anyone know if just using the dohc cluster i have caused this malfuntion, the orginal sohc cluster is being mailed to me.
240Knightrider
That very well be the problem, im guessing you got the updated ECU for the DOHC. If not then you prolly got a prob with the ECU, but I dont think the DOHC will run without the ECU. I really dont know, the only thing that comes to mind after that is the wiring was not done right or there is a connection that came loose. Check all your ground wires also.
Bigrolla
dohc ecu yes, anyone knows what happens when the dohc cluster is used over the sohc with the dohc tach
240Knightrider
that is prolly your problem. You needed to redo the whole wiring system. I hope im reading it right.
240Knightrider
and I say redo as the stuff that is different and not rewiring it to work, if that makes sense
