Help Please 2.0 turbo red top
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
Anyone can help me find Tdc for cam sensor on 2.0 turbo redtop. Thanks in advance.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
you should beable to just crank it. it will no when its TDC
xerexabante
Do you mean that I don't need to set with the TDC of the engine? I have been ****ing around helping my friend out. There are 4 squares on the camsensor plate then there is a notch on the back of the sensor I have no clue on what to do next. I have pulse on the injectors and the plugs. ????
ILikeMy240sx
Car: SR Power
you dont determine TDC condition of your motor by looking at the gears in your CAS.
First of all, put your CAS back together just the way it is.
Second of all, look at the crank pulley, you will see several notches and a needle right on top of it. Now when the needle is pointing at the second mark from the left and your #1 cam lobes are facing outwards, you are at TDC on compression stroke. This is the reference point for making sure all your mechanical timing is correct. (IE timing chain, CAS approx location, etc)
You can see your cam lobe by opening the oil filler cap. #1 cam lobe should be right underneath. That lobe should be facing outwards (towards the pass side on the intake cam)
xerexabante
Engine TDC is correct. I did'nt take off the CAS. My freind took it offf. He doesn't remember the position of the CAS. I sure don't either. Do you have pics of your CAS intalled w/ engine on TDC with CAS cover off. Thanks
