You need to check the fuel pressure first. If the fuel pump will not run, then also check the FPCU, which you should do anyway if you ran the pump into the ground as that usually takes out the FPCU also.
Next time, post some maintenance history concentrating on the intake and fuel system. New OEM fuel filter in the last year?
Finally, go around to the back of your car and read what's on the trunk.
Assume you do have an FSM and have studied it?
http://www.nicoclub.com/FSM/Q45/
