ajg35 wrote:hello all
i also just bought a 05 g35 v6 manual with 54 miles on it, i had it for a week and yesterday out of nowhere the car tempurature went sky high and it got really hot, the radiator on the car is brand new and so is the coolent flushed, but i did realize one of the fans is not working, the one in the driver side, could that be the problem or am looking at something more serious?
i do have full exust installed,
thanks for the help
Welcome to NICO
How is it a 05 G35 only has 54 miles on it?
Where did the radiator come from and who did the work?
There are a few things that are easy to do on a G but after you read the FSM on the cooling system you may decide to let the dealer check it out.
http://www.nicoclub.com/FSM/G35/Sedan/2 ... dan/co.pdf
Cooling fans are controlled by ECM. For details, refer to EC-488, "DTC P1217 ENGINE OVER TEMPERATURE
CAUTION:
Cooling fans are different between RH and LH. Be careful not to misassemble them.
OVERHEATING CAUSE ANALYSIS PFP:00012
Troubleshooting Chart ABS0001H
Symptom Check items
Cooling system
parts
malfunction
Poor heat transfer
Water pump malfunction Worn or loose drive belt
Thermostat stuck closed —
Damaged fins
Dust contamination or
paper clogging
Physical damage
Clogged radiator cooling
tube
Excess foreign material
(rust, dirt, sand, etc.)
Reduced air flow
Cooling fan does not operate
High resistance to fan rota- Fan assembly —
tion
Damaged fan blades
Damaged radiator shroud — — —
Improper engine coolant
mixture ratio
Poor engine coolant quality — Engine coolant viscosity —
Insufficient engine coolant
Engine coolant leaks
Cooling hose
Loose clamp
Cracked hose
Water pump Poor sealing
Radiator cap
Loose
Poor sealing
Radiator
O-ring for damage, deterioration
or improper fitting
Cracked radiator tank
Cracked radiator core
Reservoir tank Cracked reservoir tank
Overflowing reservoir tank
Exhaust gas leaks into
cooling system
Cylinder head deterioration
Cylinder head gasket deterioration
CO
Revision: 2005 July 2005 G35 Sedan
Except cooling
system
parts malfunction
— Overload on engine
Abusive driving
High engine rpm under no
load
Driving in low gear for
extended time
Driving at extremely high
speed
Powertrain system malfunction
Installed improper size
wheels and tires
Dragging brakes
Improper ignition timing
Blocked or restricted air
flow
Blocked bumper —
Blocked radiator grille
Installed car brassiere
Mud contamination or
paper clogging
Blocked radiator —
Blocked condenser
Blocked air flow
Installed large fog lamp
Good luck and happy 4th of July
Telcoman
