help, pilot bushing install
niswiz
Car: s13 200sx ca18det powered
hi, ordered my pilot bushing off ebay but 2 came in the package. are both to be used? also, should the bushing sit flush with the crank or hit it in as far as it will go. thanks. help needed as soon as possible. would like to install the engine this evening.
themadscientist
Two? Exactly the same? I install mine flush.
float_6969
Yea, 2 is weird. Anyway, DON'T PUT IT ALL THE WAY IN! You'll never get it back out later. It just needs to sit flush.
niswiz
realised that the auto bushing was still in so it's a good thing that 2 pilot bushings camecause one is destroyed now. used the hydraulic method to take out the bushing using ep grease. thanks guys.
float_6969
Did that really work!?!? I've tried that 3 times and all I ever got was a mess!
themadscientist
float_6969 wrote:DON'T PUT IT ALL THE WAY IN!
That's why you don't get second dates man. ;)
niswiz
yeah it does work but what u are forcing the grease in needs to be almost the same size as the internal diameter of the bushing so the grease doesn't escape at the sides. work like a charm. took about 2 minutes.
float_6969
:lolling: :tisk:
