KS_Honda_Killer wrote:You can't remove the pilot bushing. Not w/o the special little tool from Nissan.
The tool makes life easier, but there are also other tricks to getting a pilot bushing out. I suspect it is a bushing you are trying to remove (pilot bearings are available from NISMO).
Three methods of getting the bushing out:
1. Use an old input shaft, or brass rod turned down to the correct diameter to fit into the bushing. Toss a can of grease into the fridge (nice and thick). Pack the back of the bushing full of the chilled grease. use a 3/8" wooden rod (whatever) and keep packing it in so there is no air. Now put the metal rod into the bush and WHACK it with a hammer. Hydraulic action will force the bushing out. Takes me about 5 minutes.
Yes, you can use a wooden dowel just about the same size. Used to be able to find hardwood dowels, that could withstand the pounding... helps to soak it in water to swell the wood the night before you need it.
2. With a METAL TAP that is right size, you cut THREADS into the bushing. I seem to think I had a 5/8" tap... threads where cut INTO the bushing only (had the new one with me, compared ID and OD to the tap). Once threaded with a bottoming tap, dropped in a ball bearing and used a threaded a bolt into the bushing... forced the bushing out. Note crank was out at the time, so this was the easiest way to remove the old bushing.
3. With a broken hacksaw blade, carefully sliced into the bushing. Two cuts about 1/4" apart, ALMOST all the way through the bushing. Use a small chisel to cut out the 1/4" section. Seemed like it took hours, but did the job.
Favorite is #1, in all three cases wear GOGGLES. A trip to the ER to get metal out of your eye is not fun. Hint, for brass pieces they have to go digging for them... for steel the doc can use a magnet to get the pieces to the surface. Looking at your car on jack stands for a week when wearing a stupind patch on your eye is reminder to wear safety google.
Good luck,
Tom
