Help pick coilovers :D
Bosrudorfer
Car: S14
Ksport Kontrol Pro Fully Adjustable Coilover 240sx 89-98: Megan Racing Street Series Coilover Kit 240sx 89-98: Megan Racing Track Series Coilover Kit 240sx 89-98:
Looking at buying from http://www.intensepower.com/suspension14.html
Daily driver. Looking for 1.5" + drop. Will be on 16" or 17" rims.
Thanks!
Also please note I did a search.
Modified by Bosrudorfer at 6:33 PM 11/1/2005
sleepyRPS13
Car: to sleep
get the new tanabe pro seven
McRussellPants
Car: 92 240SX
Personally I think KTS is the bare minimum for quality coils.
916drifter
Car: 1990 240sx Fastback
sleepyRPS13 wrote:get the new tanabe pro seven
i second that
TrueSlide
Car: Stuff
D2s are great coilovers.
Juujai
if all you want is a 1.5" drop then do lowering springs and shocks. since its a daily driver. probably won't need coilovers.
nismofly
Car: 89 Nissan 240SX Hatch
check out the suspension FAQ for spring rates and lowering stats, thats probably a better option
babowc
Car: 240sx
dont we have a special running for the ksport coilovers?check around, we have it for sure..
Juujai
didn't notice you have a gs and a kouki 14 and you're looking into mass produced stuff from china/taiwan?
naed240sx
Car: .....
Do not get the track series. You will hate yourself forever if you do. They are way to stiff, and will send you flying off the road. Out of those choices, the original megans would be the obvious choice.
Bosrudorfer
Car: S14
Juujai wrote:didn't notice you have a gs and a kouki 14 and you're looking into mass produced stuff from china/taiwan?
Huh?
Red coupe
Car: 92 Nissan 240sx Coupe
check the road racing forum there is a pretty long thread on spring rates....I have KTS 8/6 and would honestly say for max grip in a street situation they are to stiff...in fact I had to brake reasonably hard while on the freeway the other day and the high spring rates caused my tire my left front to momentary lock up. The super high spring rates used in most coilovers are simply to much if you are using them for grip on public roads. I would look into spending around the same amount of money on a high quality shock/spring combo If I was gonna do it again (and not because of ride quality, I could care less about comfort...)
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Megan Streets.
/thread.
-Dan
teddy
Car: Saab Turbo and MR2
if all you're wanting is a 1.5" drop and just daily driving, I second the vote for just springs/shocks. If you're set on coilovers, the Megan or KTS would be a big bang for the buck, or check out powertrix coilovers. I've read that they're pretty good and not so expensive.
