help pick 16" tire size.. 205/55, 215/55 or 225/50
Bosrudorfer
Car: S14
Got some 16x7 with +24 offset. Car has 1.5" drop in front and 1" in rear. So far I am leaning with 215/55/16.
Tires will be GForce Sports. I could get fuzions though.
Thanks family
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
What are you wanting to do with your car?
SmithSR
Car: 240sx
You have an S14?215/55-16 is stock size for the older Maxima.I'm a fan of the simple 205/55-16. Matches OEM 240SX diameter perfectly.And they weigh less, and good tires will give you just as much grip, lateral or otherwise, as a bigger size.
Bosrudorfer
Car: S14
SR_Smith wrote:You have an S14?215/55-16 is stock size for the older Maxima.I'm a fan of the simple 205/55-16. Matches OEM 240SX diameter perfectly.And they weigh less, and good tires will give you just as much grip, lateral or otherwise, as a bigger size.
Yes its an 98 S14. The rims have a good 1" or so lip on them too I forgot to mention. As for purpose light drifting, but most daily driving.
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
All I got to say is don't get Fuzion's they're poop and don't last very long. They are low-end Bridgestones.
SmithSR
Car: 240sx
^^True!
Bosrudorfer
Car: S14
SR_Smith wrote:^^True!
Yea I will go for the GF sports so then 215/55/16 is decided. Thanks all I'll post pics when I get them on.
Bosrudorfer
Car: S14
I called the tire shop and they dont have any G-Force sports right now but offered me a choice between BFGoodrich Traction T/A for $90 or Yokoma White K420 for $123. Which of the two would you recommend?
Looneybomber
10 G37S (white)
Bosrudorfer wrote:I called the tire shop and they dont have any G-Force sports right now but offered me a choice between BFGoodrich Traction T/A for $90 or Yokoma White K420 for $123. Which of the two would you recommend?
What about some Azenis FK-451's? 84/tire in a 215/55/16http://www.vulcantire.com/451_t.htm No need to buy some expensive tires if you're just going to eat them up drifting.
Eddie
Car: 1995 240sx se
Not busting your chops or anything, but the Yokos are called YK420.
Out of the traction T/A and the yk420 I would get the traction T/A, but you should just wait for the G-Force sports if that's what you want. I am strongly considering the g-force sports next time I get tires.
Bosrudorfer
Car: S14
Hey guys, in the end I ordered the G-Force sports and they should be in Wednesday. Not bad for $80 bucks a pop.
Bosrudorfer
Car: S14
Hi guys,I actually got the 215/55 but dont like them, they look to big! The sidewall is too big and the height is also so the tire shop will switch them for a smaller size but I am still deciding.
Which one?
205/55 or 205/50 or 215/50?
Thanks!
nismofly
Car: 89 Nissan 240SX Hatch
i posted in your other thread just so you know
ReD*PiG
Car: 1990 240sx SRpowerd
Hey,Fellas I'm also gunna be looking for tires by next week or the week after.I am waiting for my wheels to come from Japan..Wantanabe rs8.But also not sure of what tire size to go with.My car has gr2s with sportlines.I would like to fill a little fender space but also have a lower profile.The wheels are "16 X 7 in front and "16 X 8 in rear both with a +35 offset.Thanks...
skydragoness
I'm curious how a 225/50/16 would fair on a 16x7.5 +32 wheel on the front. Wondering if there will be scrubbage on my agx's. Or maybe 215 would be better.
nismofly
iirc Bronze MFP had 225/50/16 on his wheels that were that size and they worked fine
of course i run that tire and wheel size but mine are +22
nismofly
ReD*PiG wrote:Hey,Fellas I'm also gunna be looking for tires by next week or the week after.I am waiting for my wheels to come from Japan..Wantanabe rs8.But also not sure of what tire size to go with.My car has gr2s with sportlines.I would like to fill a little fender space but also have a lower profile.The wheels are "16 X 7 in front and "16 X 8 in rear both with a +35 offset.Thanks...
205/55/16 and 225/50/16
ReD*PiG
Thanks man.......225/50/16 in the rear right?The only thing I dont like about getting diffrent sizes in the rear is then you cant rotate your tires.Oh, well it will definitly look better and perform better though right?
nismofly
you might notice a bit of understeer with the stagger, but theres ways to fix that
wont perform better without good tires, the impact size has on performance is little to none
the reason youve got different size tires is because youve got different size wheels
skydragoness
nismofly wrote:iirc Bronze MFP had 225/50/16 on his wheels that were that size and they worked fine
If I get them and find out they scrub ... I'M GONNA COME AFTER YOU! (and I'll just rip that seat right out of you car, i'm sick of waiting! :D)
ReD*PiG
Lol....Duh, what the hell was I thinking!! Thanks man....Yeah,as far as the understeer goes I can swap the rear swaybar right?
nismofly
ReD*PiG wrote:Lol....Duh, what the hell was I thinking!! Thanks man....Yeah,as far as the understeer goes I can swap the rear swaybar right?
yeah a 20mm stagger can be made up fairly easily
skydragoness wrote:If I get them and find out they scrub ... I'M GONNA COME AFTER YOU! (and I'll just rip that seat right out of you car, i'm sick of waiting! :D)
ask him if you want to be positive
shouldnt be a problem though, especially since you dont have coilovers
SmithSR
Car: 240sx
225/50-16 on Z32 (16x7.5) wheel rubbed on coilover and also on GR2, on front.205/55-16 a very small gap, but still cleared.
That's on a +45 offset
SmithSR
Car: 240sx
Christine do you need an S14 seat?
skydragoness
Do they have more lateral support than the S13 base model seat? I'm not expecting much really.
SR_Smith wrote:225/50-16 on Z32 (16x7.5) wheel rubbed on coilover and also on GR2, on front.205/55-16 a very small gap, but still cleared.
so on my 7.5' +32's should 225/50 be ok? my rear SSR's are 8'' which is why i wanted to stick with 225 all the way around
McRussellPants
Car: 92 240SX
skydragoness wrote:Do they have more lateral support than the S13 base model seat? I'm not expecting much really.
If you weigh under 150lbs your gonna wallow around in any stock seat. I'm 225 and S14 Seats still don't work right.
I heard you were looking at Buddy Club or something? Get a shell, SPL should be getting theirs in sometime soon and my Emo friend fits in perfect.
skydragoness
McRussellPants wrote:If you weigh under 150lbs your gonna wallow around in any stock seat. I'm 225 and S14 Seats still don't work right.
ROFL. Emo kids. They need to eat more.
Me, i'm 5'3, 118lbs, so i slide around in my SE coupe seat. However, I sat in many basemodel seats (the ones with no seperate headrests) and they seem to be more snug. I wish I could get a Buddy Club, but they're just too much $ for me to spend right now. I'll just wait for Nismofly to get rid of his.
nismofly
im the one getting buddy clubs
just have to figure out when, some time this summer
ReD*PiG
Nismofly, so I should be good with the 205/55/16 in front and the 225/50/16 in the rear right?Sorry to ask again but the wheels are on there way,and I just want to be absolutly sure.Thanks man......
nismofly
yep, that will be fine
