HELP phone book question
tintman1
Car: 06 m45
Just bought a 06 m45 didn't have the owners manual but the phonebook is full of the prev owners numbers and I cannot figure out or find a way to delete them, any help would be great thanks
BigP
Car: 2006 M45
I had the same problem two months ago. I don't have the manual with me but I did not use it to figure it out.
If no one else posts the answer I'll come back later with more info.
I recall you have to delete them one at a time. Keep trying and you should figure it out.
EniGmA1987
Car: '06 Infiniti M35 Sport
Ill post back how to do it when I get back from lunch in an hour or so. Ill look at it when I get in my car.
tintman1
Car: 06 m45
thanks
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
If you access the Confirmation/Adjustments Menu and scroll to the bottom and access the connection log if you delete that it should take care of many of the old settings and locations that were used by the previous owner. I do this on every used M I get. It should set just about everything back to the original empty setting, I know this works for the phone, phonebook and a few other settings. I am not 100% if this will remove the Nav locations, though.
To access the Confirmation/Adjustments menu turn the car to the ON position (engine on or off) with the radio OFF press and hold the SETTINGS button and turn the radio volume knob until you hear a beep and the screen changes to a screen with two options, select the lower option, using the wheel scroll all the way to the bottom to find the Connection Log.
EniGmA1987
Settings -> Phone -> Phonebook -> select number -> delete
I thought for sure I deleted all of the numbers at once in my car, but I could be mistaken. I couldnt seem to find a delete all area
tintman1
Car: 06 m45
thank you everybody
tintman1
Car: 06 m45
SteveTheTech wrote:If you access the Confirmation/Adjustments Menu and scroll to the bottom and access the connection log if you delete that it should take care of many of the old settings and locations that were used by the previous owner. I do this on every used M I get. It should set just about everything back to the original empty setting, I know this works for the phone, phonebook and a few other settings. I am not 100% if this will remove the Nav locations, though.
tried that and they are still in there, i cannot find a delete button either
blazin_mtl
Car: M35X 2006
All manuals and warrantee info is on the Infiniti site in PDF format.http://www.infinitiusa.com/iap...uides
