Well I have pulled the ecm and checked it over thoroughly. ic-17 was not burnt nor did it have any burnt smell. I checked the entire board and could find no evidence of a malfunction to the ecm. But has anyone experienced needing to repair the board even without any physical evidence of damage? I am about to the conclusion that this must be so. I'm at the point I am thinking that I should just replace the chip on the ecm that usually fails from the IACV going bad and see what happens.
I confirmed I have power at the IACV harness, and continuity. The only other thing I am wondering is if it would make a difference if I have not bled the cooling system since replacing the IACV? I am going to try that when i get home after work. Other than that I have just about exhausted every other avenue. Tested tps and it was good, checked everywhere for vacuum leaks, nothing.
