help.. pathfinder control arm replacement
OUKNO
Car: 1990 Z32 NA, 1974 International Scout
any one have a tutorial/link for a pathfinder rear control arm replacement
nissandoms47
Car: 2002 Nissan Pathfinder SEV6-Custom 7" lift-33-1250R15 BFG KM2- a bunch of other s*** i cant think of
Its really not that hard.. just jack up the truck so the rear axle is suspended then remove one control arm at a time and replace with new. Dont remove all of the control arms at once or you'll be spending hours trying to realign the axle to the truck. You'll most likely have to cut the lower control arm axle side bolts since they tend to rust to the bushing sleve. So make sure you pick up some more bolts at the dealer before you begin.
