All of your codes are related to water immersion. And it's not a good idea to operate a car with bad O2 sensors for extended period as the engine tends to run richer which can damage the remaining O2 sensors, and worse, the expensive catalytic converters (3 each - Bank 1 and Bank 2 Pre-Cats and Main Cat).
For P1444, check all the tubings to/from the Evap Canister (back of the car near gas filler tube) for cracks or loose connections. Make sure you label each tubing before disconnecting it as wrong installation can create more problem. Most likely a cracked or loose tubing allowed water ingestion, clogging the lines with water. Remove any water from the system. Replace/tighten the affected tube.
As for the O2 sensor problems, they can easily get damaged by water. There are 4 sensors and most likely the lower 2 sensors (Rear sensor, downstream of respective Pre-Cat) were immersed in water. These REAR O2 sensors (HO2S2-B1 with WHITE harness1 & HO2S2-B2 with RED harness) have 4-wire connectors mounted near the radiator. The HO2S2-B1 sensor is mounted in front of Bank 1 Pre-Cat (horizontal mounting) while HO2S2-B2 is mounted on the vertical section of the pipe, downstream of Bank 2 Pre-Cat. There is no O2 sensor for the main cat. BTW, Bank 1 is towards the firewall while Bank 2 is towards the radiator.
Safely jack up the front pax side (use jack stand) and once under the engine, follow the exhaust pipe and look for the WHITE and RED harnesses leading to the respective sensor. Use a liberal amount of WD-40 or PB Blaster and use an O2 Sensor Adapter (@ $10, long socket with opening on the side) during removal/installation.
You have a choice of using the OEM Bosch sensor (expensive @ $150), the OEM-compatible NGK/NTK sensor(@ $90) or Universal (<$50 but requires splicing and knowledge of wiring diagram. Our NICO sponsor, NGK.com, a.k.a. "sparkplugs. com sells these O2 sensors , P/N: 24572 and 24574 for @ $90 each. See link below. If you are lucky, you can get it cheaper from Amazon.
http://www.ngk.com/results_app.asp
Once you have fixed the problem you have to complete the SRT (System Readiness Test) in order to pass SMOG check. I can give you instructions on how to do this but if you have a scanner, it will tell you which parameters are READY or NOT READY. In CA we are allowed a maximum of 2 NOT READY sensors, provided CEL is off and emission requirements are met, to pass the test.
