MX3ze@7psi »
https://forums.nicoclub.com/mx3ze-7psi-u156723.html
Sat Mar 20, 2010 9:38 am
Hi there new to this forum. Having a problem with the pathfinder. Got the code p1320 so I've changed all the coil packs and plugs, reset the ecu and still getting the code and car still stalls. Now I'm getting a p0732, p0733, and p0160. Now the transmission and 02 sensor. The car stumbles at idle, sometimes die. Everytime you drive it, if you give it alot of gas it doesn't move. The motor doesn't even rev up. Its like its delayed a 3 second delay before it revs up stumbling. I don't know anymore. The dealer said just change out the coils and all good, but nothing changed. I got coils from O'reily's. The coils looked like OEM nissan ones that had the nissan stamp scratched off on the tube going down to the plugs and also the top numbers too. Need some help.
