Hello all, just joined here in hopes to find some answers and gain some knowledge in the future. I just bought a 2003 Infiniti I35 for my daughter about a month ago. When I bought it, it was obviously running fine. No real issues that I could tell. A couple days ago however, the SES light came on. After that point, I noticed the car almost immediately started running really rough (vibrating, sputtering, etc). She drove it for a day or two back and forth from work and I was planning on checking the codes over the weekend. Friday evening I took it for a test drive and noticed the oil light came on. I immediately stopped and added some oil. I then went to get the codes checked and I got a P0011, P0021 and P0303, so IVT and cylinder 3 misfire. I spoke with a few mechanics and they are all over the place with their "diagnosis" so I figured I would do some research. One of the mechanics said I need to replace the cam and crankshaft position sensors. That seems odd that I would need to replace all the position sensors. So, with that being said, Any ideas?
Thank you in advance.
