redbeardxxv »
https://forums.nicoclub.com/redbeardxxv-u155884.html
Wed Nov 17, 2010 7:56 am
Ok, so recently, we had a cold snap, and I noticed that my heat took forever to come on, and that it was only warm, not hot. After searching the forums, I found that it could be the thermostat. So, I changed mine. While changing the thermo, I noticed my coolant was all rusty. So I flushed the system. 2 days later, my water pump went. So I changed it. Again,while I was in there, I flushed the system just to be sure. Now, with a new water pump, and a new Thermostat and new coolant, I keep overheating. Fine in the driveway, but once I run the car for 10-15 minutes, slow speeds, stop lights, etc. cause me to overheat. I did put in a strong mix of coolant vs water, and I did paint the outside of the water pump. Neither should make any difference. So WTH??? I refilled the coolant through the radiator, pulled the bolt out that relieves the pressure and filled it until the coolant came out there. What else can i do? Anyone know why I keep overheating?
