help out Tramp_d, starting/running issues.
tramp_drift240
Car: 1992 240sx SE Coupe
92 coupe with kade.
a few weeks ago i started noticing my car would kinda buck until the motor warms up, like hiccupping as i try to accel. it goes away once it warms up, but will still occasionally hic a bit while im out driving.
also, its taking an unreasonably long time for my car to actually start. like 5 seconds of cranking before it turns over. and even then, it seems like its running on two or three cylinders, and smooths out and runs like normal.
i just had to replace my battery because i was draining the cranking amps over the past week or two starting my car.
im thinking fuel pump, but im not really sure. advice would be helpful, id really like it to be fixed.
Gabes13
Car: rb20det s13
This may have little relevance for you, but...
1. My sohc "hiccuped" upon throttle a while ago. My TPS wasn't set right.
2. My brother in law's Maxima would crank but would take forever to turn over. One of his vacuum hoses were plugged.
tramp_drift240
well it just does the hiccup til it warms up. and sometimes bucks when im just cruising or speeding up slowly.
and of course ive got vaccuum lines plugged up, i dont need any but two currently.
ill look into it though, for sure. thanks for the input man.
AZ89two4Tsx
Sounds like you need a new engine.
tramp_drift240
AZ89two4Tsx wrote:Sounds like you need a new engine.
informative reply, sir. well played, take the free posts somewhere else.
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
MGE is sitting right next to me. He says:
"Vacuum leak potentially""MAF plug not getting a good connection""Coolant temp sensor"
MastaYu
Car: 92 Nissan 240SX SE HB
Are your injectors good?
tramp_drift240
MastaYu wrote:Are your injectors good?
probably not. ive been through a handful of them over the past few years.
id like to have a whole new set, but i dont want to spend the money to get guaranteed good injectors when im wanting to upgrade for boost down the road.
