Help out on offset?
mac11
Car: 240sx
I need new wheels on 240sx hb.I have 5lug conv,Z32tt on front and teinflex coil.Need to know if this offset will clear Zbreak and teinflex w/out wheel spacers?Pls help out thanks.
Work meister S1 2pc17x9 +5 235/4017x10 +10 255/40
Work meister S1 18x9 +5 225/4018x10 +10 245/40
Modified by mac11 at 9:18 PM 7/15/2006
naed240sx
Car: .....
Both of those will easily clear coilovers.
Offset is not he main concern when considering brake clearance. Spoke design is more important. Meisters will definately clear Z brakes.
You are definately gonna have some major fender clearance issues though.
mac11
Car: 240sx
Thanks for the Info.Any body have the same set up?or close to that w/out fender flares with by 9front and 10rear.Pls any body PIC size or off set that helps.
naed240sx
Car: .....
mac11 wrote:Thanks for the Info.Any body have the same set up?or close to that w/out fender flares with by 9front and 10rear.Pls any body PIC size or off set that helps.
Here is 17x9+20 with 235/40s and -1.8 degrees camber. My front fenders are rolled and pulled a bit.
Yours would stick out 15mm farther.
