Help our Z! Lights flashing! Buzzing noise!
Muhib
Car: 04 Nissan Maxima SE 6MT Elite Package
90 Nissan Pearl Yellow 300ZX TT
So I went to this place today and shut off the car. Came back about 10 mins after. Started as usual and there was buzzing noise, with HICAS, antilock, LIGHTS, battery and parking brake light on. I slowly drive away and the lights go away too except battery and parking brake light. The parking brake light stays on but very dim. The antilock goes away but HICAS and LIGHTS become dim as soon I drive very slow or stop at an intersection.
The car drives just fine but the buzzing noise and lights flashing is making me worried. Could be a serious problem... :ohno:
90 Z TT, 256000 kms
Help me guys! I need the car badly cuz at my work there isnt really a bus route :frown:
NolimitZ32
Alternator went bad possibly? the buzzing could be the bearing or another electrical component, sounds odd, can you post a video?
Muhib
Thanks for your reply.
Hmm replacing alternator should not be that expensive right? Forgot to add that this weekend we got a jvc single din cd player installed. Could it be that it is messing with some electrical component?
I will post a video later on.
PAintballa45
Car: 1991 300zx n/a (TT in progress : D) slicktop
I just had the same problem and my alt was overcharging the entire car, test the battery terminals with a multimeter at idle and reving the engine. It should never go over 14.4. Where is the buzzing coming from? Mine was from the fuel pump (behind drivers seat) and was fried by the higher voltage
Muhib
for some reason everything is fine now on its own :confused:
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Do you have subs? If so, there may be a short somewhere along the power cable.
