cargood »
https://forums.nicoclub.com/cargood-u2525.html
Mon Jan 13, 2003 3:31 pm
Well, I've done a compression test on it, and all the cylinders are reporting the same number : around 182 psi, which is about normal.
So if its not the valves or the sparks, is it pretty much the fuel supply? What else can it be? Thanks.
