orlando210 wrote:oh ok where did you hook up the red and black wire at?
the red and black leads that dont have a connector gets plugged into the factory connector ( make sure you use a volt meter or test light to find your 12v source ) the other cannon plug with the yellow weather insullator gets plugged into the ballast then to the light bulb , make sure you do not let the red and black touch it will fry the ballast thats why i used shrink wrap , silicone and the modded plug
Modified by nickwillhite at 6:18 AM 1/7/2009
