HELP ON THIS SETUP?
98silvia
i ordering a t28 ball bearing turbo for my s13 red top, and i getting 550cc injector. how safe do you think this setup is without touching the internal? should i get the head gasket? cam? rocker arm stop? or valve spring? .here is the link that i turbo kit i want. http://cgi.ebay.com/ebaymotors...%3AITi just want about 250-300 wheel horsepower, but i afriad to brow my motor. any help will be great.
98silvia
Do i even need the injector? the reason i doing this, because my stock turbo is going out. i just wanted to run about 10-12 pound of boost.
luv2spedup
Car: 89 silvia
well u need a head gasket(metal) and arp head studs for sure
luv2spedup
Car: 89 silvia
and with the injectors u want u can crank the boost up to
daz1320
Car: '93 vert
luv2spedup wrote:and with the injectors u want u can crank the boost up to
huh??????
