help on s13 fold in mirror wiring!!!
Brian*
Car: 1995 Nissan 240sx (S14)
Just got a set of fold in mirrors for my s13, my buddy said I was goin to have to get the wiring diagram before i even thought about wiring them... anyone know where I can get that??
vancouverbc
Car: 1991 240sx
I have my 1991 stock mirror here. There are 3 wires going to mirror; purple, yellow, and blue. Those are the colours in the harness just as it connects to mirror. There is a link to service manual in my sigature. I think there are some wiring diagrams where it says pdf foldout. I can tell you what the wires are for if you like.
Modified by vancouverbc at 9:12 PM 5/11/2006
vancouverbc
Car: 1991 240sx
wires at the switch:
blu-white- 12v from fuse eppl-white- splits and goes to both mirrorsblack- groundyel-black-right mirrorblu-black-right mirroryellow-blu-left mirrorblu-red-left mirror
found the following post related to this matter. no idea if it makes sense.
"Well I have this information from one guy... pull out your stock mirror switch. match it up to the jdm one. you will notice that the jdm one has 2 extra wires, one white, one blue. get a pin pusher, and put those 2 wires into the usdm connecter. put the jdm switch in the usdm connector. run a blue wire from the switch through the dash, then split it and run it to both mirrors. do the same with the green wire. bam, your done. its easy, the hardest part is getting the wires throughthe door jam and running them through the dash board. make sure that you zip tie the door wires to the existing wiring harness so they dont get tangled in your window when it goes up and down.I need info push into the usdm connector but to which one???"
Modified by vancouverbc at 1:36 PM 5/12/2006
