Hello. Currently I own a 66 mustang so all my expertise is with carburetted, n/a 289's and 302's. However I plan on selling it this summer and am pretty much set on building up a CA18DET and putting it into a 510.
After many hours of reading this forum, 240sx.com, and various other links, I believe I've put together a pretty complete rebuild/build list of parts. My goal is to get around the 350hp mark in a reliable manner.
Couple questions:Head gasket- I went onto cometic's site looking for head gasket. The only listed gasket I found had a 85mm bore. Will this work for the CA18DET, or did I overlook a gasket with a 83mm bore?FMIC- I have absolutely no clue about what companies are reputable in these? Any suggestions?Radiator- I know about the electric fan from the escort, but is there a preferred radiator that seems to work, mount, etc. better with the CA?Gasket Kit- Is there a site where I can still order the gasket kit for the whole engine?
Parts:CA18DET
http://www.jazzproparts.com/Pr...18DETXT (CP?) Pistons
http://www.raceeng.com/p-7957-....aspxPauter Rods
http://www.pauter.com/nissan.htm SSautochrome T3/T4 top mount manifold
http://www.ssautochrome.com/level.itml/icOid/1358Walbro 255 http://www.injectedperformance...=1635NISMO FPR http://performancenissanparts....=2552New Water Pump for 1984 CA18ET
http://www.partsamerica.com/Pr...Set=AACT S13/S14 SR20DET Clutch http://phase2motorsports.store....htmlNISMO Motor and transmission Mounts http://performancenissanparts....=2544Garrett T3/TO4E 50 Trim with .63 A/R Housinghttp://cheapturbo.stores.yahoo....htmlHKS Standard Wastegate
http://www.hksusa.com/categories/?id=1940Z32 MafARP BoltsDSM injectors
Anything I'm overlooking? Thoughts, opinions? Also, I plan on going megasquirt with this, do I still need to mess with the ecu and that jazz? Thanks guys.
I'm not averse to doing my own research, in fact, I'd almost rather do it, but a little guidance and help would be appreciated. Remember, this is an entirely new world for me, as it's just about as far away from a 66 na 289 as I can get. Thanks againl
Modified by shiboboo at 12:44 AM 12/16/2007
Modified by shiboboo at 1:32 AM 12/16/2007
Modified by shiboboo at 1:35 AM 12/16/2007
